Kingston HyperX Genesis 2GB (2 x 1GB) DDR3 1333MHz Non-ECC CL7 DIMM
Quicklinx: 75WHWS00 Mfr#: KHX1333C7AD3K2/2G
HyperX Genesis - DDR3 - kit - 2 GB: 2 x 1 GB - DIMM 240-pin - 1333 MHz / PC3-10600 - unbuffered
Memory kit
2 GB: 2 x 1 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1333 MHz (PC3-10600)
Latency Timings
CL7
Dual channel, unbuffered
Voltage
1.65 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
2 GB: 2 x 1 GB
Upgrade Type
Generic
DRAM memory kit
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL7
Non-ECC
Module Configuration
128 x 64
Voltage
1.65 V
Lead Plating
Gold
Compatible Slots
2 x memory - DIMM 240-pin
