Kingston HyperX Blu 2GB 1600MHz DDR3 Non-ECC CL9 DIMM
Quicklinx: 741QWS00 Mfr#: KHX1600C9AD3B1/2G
HyperX blu - DDR3 - module - 2 GB - DIMM 240-pin - 1600 MHz / PC3-12800 - unbuffered
Memory module
2 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL9 (9-9-9-27)
Unbuffered
Voltage
1.7 - 1.9 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
2 GB
Upgrade Type
Generic
DRAM memory module
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9 (9-9-9-27)
Non-ECC
Unbuffered
Module Configuration
256 x 64
Voltage
1.7 - 1.9 V
Lead Plating
Gold
Compatible Slots
1 x memory - DIMM 240-pin
