Kingston HyperX 6GB (2GB 256M x 64-Bit x 3 pcs.) DDR3-1600MHz CL9 240-Pin DIMM Kit
Kingston's KHX1600C9D3K3/6GX is a kit of three 256M x 64-bit 2GB (2048MB) DDR3-1600MHz CL9 SDRAM (Synchronous DRAM) memory modules, based on sixteen 128M x 8-bit DDR3 FBGA components per module. Each module kit supports IntelĀ® XMP (Extreme Memory Profiles). Total kit capacity is 6GB. Each module kit has been tested to run at DDR3-1600MHz at a low latency timing of 9-9-9-27 at 1.65V. The SPDs are programmed to JEDEC standard latency DDR3-1333MHz timing of 9-9-9 at 1.5V. Each 240-pin DIMM uses gold contact fingers and requires +1.5V.
- HyperX - DDR3 - kit - 6 GB: 3 x 2 GB - DIMM 240-pin - 1600 MHz / PC3-12800 - unbuffered
- Product Type
- Memory kit
- Capacity
- 6 GB: 3 x 2 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 1600 MHz (PC3-12800)
- Latency Timings
- CL9 (9-9-9-27)
- Eight banks, On-Die Termination (ODT), Intel Extreme Memory Profiles (XMP), triple channel, unbuffered
- Voltage
- 1.65 V
- Lead Plating
- Gold
- Limited lifetime warranty
- Capacity
- 6 GB: 3 x 2 GB
- Upgrade Type
- Generic
- DRAM memory kit
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Module Height (inch)
- 1.18
- Speed
- Latency Timings
- CL9 (9-9-9-27)
- Non-ECC
- Module Configuration
- 256 x 64
- Chips Organization
- 128 x 8
- Voltage
- 1.65 V
- Lead Plating
- Gold
- Compatible Slots
- 3 x memory - DIMM 240-pin
