Kingston Elite Pro - Flash memory card - 8 GB - 133x - CompactFlash
Quicklinx: 4TY5WS00 Mfr#: CF/8GB-S2
Imaging pros expect a lot from their equipment and can't afford to have a component limit their productivity or creativity. That's where Kingston's CompactFlash Elite Pro memory cards come in. The newly redesigned Kingston CompactFlash Elite Pro offers a minimum sustained write speed of 133X. The Elite Pro is designed specifically to help advanced amateur or professional photographers get the best performance from their high-end imaging devices and applications.
No matter how fast you work, CF Elite Pro can keep pace. With its ultra-fast transfer rates of 25MB/sec. read and 20MB/sec. write, and great capacity, you can capture more continuous, high-resolution images in less time with the Elite Pro than with traditional CompactFlash memory cards. And when it's time to transfer your largest files, watch them fly your production workflow will be more efficient than ever.
  • Enhanced durability
    Designed to withstand a wide range of environmental conditions, the Kingston Elite Pro flash memory card operates flawlessly between 0°C and 60°C. Its robust design ensures your data remains safe and accessible, even in extreme temperatures.
  • Efficient data management
    Featuring an auto-sleep mode, this CompactFlash Card conserves power when not in use, extending the battery life of your devices. It's an ideal choice for photographers and videographers looking for efficient power management in their storage solutions.
  • High-speed performance
    With a read rate of 25 MB/s and a write rate of 20 MB/s, the Kingston Elite Pro offers reliable high-speed data transfer. This speed rating of 133x makes it suitable for high-resolution image and video file storage, ensuring smooth and efficient workflows.
Kingston Elite Pro - flash memory card - 8 GB - CompactFlash
Flash memory card
CompactFlash Card
Size (Type)
Type I
Storage Capacity
8 GB
Speed Rating
133x
Limited lifetime warranty (Germany, Austria and France - 10 years)
Flash memory card
Storage Capacity
8 GB
Speed Rating
133x
Read Rate
Up to 25 MB/s
Write Rate
Up to 20 MB/s
CompactFlash Card
Size (Type)
Type I
Auto-sleep mode
Plug and Play, CFA
Limited warranty - lifetime , Germany: limited warranty - 10 years , Austria: limited warranty - 10 years , France: limited warranty - 10 years
36.4 mm
42.8 mm
3.3 mm
60 °C
