Kingston DDR3L 4 GB SO-DIMM 204-Pin 1600 MHz / PC3L-12800
Quicklinx: BZKSWS00 Mfr#: KCP3L16SS8/4
Type: DDR3L SDRAM
Capacity: 4GB
Connection: SO-DIMM 204-pin
Speed: 1600MHz
Data Integrity: Non-ECC
£17.14 ex VAT
£20.56 inc VAT
Kingston Technology is the world’s independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
Kingston - DDR3L - module - 4 GB - SO-DIMM 204-pin - 1600 MHz / PC3L-12800 - unbuffered
Memory module
4 GB
Memory Type
DDR3L SDRAM - SO-DIMM 204-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3L-12800)
Latency Timings
CL11
Low Voltage, unbuffered
Voltage
1.35 V
Lead Plating
Gold
Panasonic CF-WMBA1104G, HP 691740-001, HP H6Y75AA, HP H6Y75UT, Toshiba PA5104U-1M4G, Panasonic CF-WMBA1204G, HP D0H47AV, DELL A6950118, DELL A6951103, Panasonic CF-WMBA1304G, Panasonic CF-BAX04GI, Lenovo 0B47380, HP H6Y75ET, Panasonic CF-BAS04GU
Limited lifetime warranty (Russia - 10 years)
4 GB
Upgrade Type
Generic
DRAM memory module
DDR3L SDRAM
SO-DIMM 204-pin
Speed
Latency Timings
CL11
Non-ECC
Module Configuration
512 x 64
Voltage
1.35 V
Lead Plating
Gold
Colour Category
Green
Type: DDR3L SDRAM
Capacity: 4GB
Speed: 1600MHz
Registered/Buffered: Unbuffered
CAS Latency: CL11
Standard: PC3L-12800
Brand: Kingston
