Kingston Technology is the world’s independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
- Kingston - DDR3L - module - 16 GB - DIMM 240-pin - 1333 MHz / PC3-10600 - registered
- Product Type
- Memory module
- Capacity
- 16 GB
- Memory Type
- DDR3L SDRAM - DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 1333 MHz (PC3-10600)
- Low Voltage, registered
- OEM Manufacturer Equivalent Part Number
- IBM 49Y1563
- Limited lifetime warranty (Russia - 10 years)
- Designed For
- Lenovo Flex System x240 Compute Node 8737; x440 Compute Node 7917; System x3300 M4 7382; x3500 M4 7383; x3530 M4 7160; x3550 M3 7944; x3550 M4 7914; x3630 M4 7158; x3650 M3 7945; x3650 M4 7915; x3690 X5 7147, 7148; x3750 M4 8722; x3850 X5 7143; x3950 X5 7143, 7145
- Capacity
- 16 GB
- Upgrade Type
- System specific
- IBM 49Y1563
- DRAM memory module
- Technology
- DDR3L SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- ECC
- Designed For
- Lenovo Flex System x240 Compute Node 8737 , Lenovo Flex System x440 Compute Node 7917 , Lenovo System x3300 M4 7382 , Lenovo System x3500 M4 7383 , Lenovo System x3530 M4 7160 , Lenovo System x3550 M3 7944 , Lenovo System x3550 M4 7914 , Lenovo System x3630 M4 7158 , Lenovo System x3650 M3 7945 , Lenovo System x3650 M4 7915 , Lenovo System x3690 X5 7147, 7148 , Lenovo System x3750 M4 8722 , Lenovo System x3850 X5 7143 , Lenovo System x3950 X5 7143, 7145
