Kingston DataTraveler Workspace 64GB
Quicklinx: 8JGJWS00 Mfr#: DTWS/64GB
The Kingston's DataTraveler Workspace allows IT and administrators to easily support such work styles as "bring your own PC", mobile workforce and the needs of contingency staff, who need access to the corporate environment without security compromise. This USB 3.0 drive incorporates SSD controller technology to produce a high-performance, low-latency drive.
  • High-speed performance
    Experience swift data transfer with the Kingston DataTraveler Workspace, featuring read and write rates of 250 MB/s. This USB flash drive is designed to enhance your productivity and efficiency, whether transferring large files or executing demanding applications.
  • Enhanced compatibility
    The Kingston DataTraveler Workspace boasts broad compatibility, supporting both S.M.A.R.T function and TRIM support. This ensures a seamless and optimized experience across various devices and systems, making it a versatile choice for professionals and casual users alike.
  • Durable and reliable
    Built to withstand the rigors of daily use, this USB flash drive operates within a wide temperature range from 0°C to 60°C. Coupled with a SandForce SSD Controller, it offers both durability and reliability, safeguarding your data in diverse environments.
Kingston DataTraveler Workspace - USB flash drive - Windows To Go certified - 64 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
64 GB
Microsoft Windows 7, Windows 8
Windows To Go Certification
USB flash drive
Storage Capacity
64 GB
Read Rate
Up to 250 MB/s
Write Rate
Up to 250 MB/s
Interface Type
USB 3.0
Bootable, S.M.A.R.T function, SandForce SSD Controller, TRIM support
ISO 9001:2008
75.29 mm
22.98 mm
16.44 mm
60 °C
