Kingston DataTraveler Vault Privacy 32GB USB 3.0 256bit AES Encryption Flash Drive
Quicklinx: 9FHWWS00 Mfr#: DTVP30M-R/32GB
Kingston's DataTraveler Vault Privacy 3.0 (DTVP 3.0) USB flash drive provides affordable business-grade security with 256-bit AES hardware-based encryption using XTS block cipher mode, which offers stronger protection than CBC and ECB modes. It protects 100 percent of data stored and enforces complex password protection with minimum characteristics to prevent unauthorized access. For additional peace of mind, the drive locks down and reformats after 10 intrusion attempts. It also features a read-only access mode to avoid potential malware risks.
Companies can add DTVP 3.0 to their standards list with confidence since its industry-leading NAND and controller design allow for NAND to be interchanged without requalification and certification of security features. Plus they no longer have to compromise transfer speeds for safety, due to DTVP 3.0's SuperSpeed USB 3.0 technology and backwards compatibility with USB 2.0.
Companies can also customize the DTVP 3.0 in a variety of ways to meet specific needs and the most frequently requested internal corporate IT requirements, such as serialization numbering, number of attempted password entries, minimum password length and customized product identifier (PID) for standard end-point management software (white-listing).
  • Secure storage
    Equipped with hardware encryption, the Kingston DataTraveler Vault Privacy 3.0 Management-Ready USB flash drive offers a secure way to store and transport sensitive information, ensuring that your data remains safe even if the drive is lost or stolen.
  • Durable design
    This USB flash drive is not only waterproof, providing an extra layer of protection against damage from liquid spills and submersion, but also operates reliably across a wide range of temperatures, from 0°C to 60°C. Its robust design ensures your data is protected in various environmental conditions.
  • High compatibility
    With a USB 3.0 interface, the Kingston DataTraveler Vault Privacy 3.0 Management-Ready ensures fast data transfer speeds and is compatible with a wide range of devices, making it a versatile choice for both personal and professional use.
Kingston DataTraveler Vault Privacy 3.0 Management-Ready - USB flash drive - 32 GB - TAA Compliant
USB flash drive
Interface Type
USB 3.0
Storage Capacity
32 GB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash
Software Included
Blockmaster SafeConsole
Microsoft Windows Vista SP2, Microsoft Windows 7 SP1, Windows 8, Windows 8.1, Apple MacOS X 10.6 - 10.9
TAA Compliant
5-year warranty
USB flash drive
Storage Capacity
32 GB
Hardware Encryption
256-bit AES
Read Rate
Up to 250 MB/s
Write Rate
Up to 40 MB/s
Interface Type
USB 3.0
NAND Flash
Password protection, waterproof, aluminum body, Read-Only Access Mode
TAA Compliant
Software Included
Limited warranty - 5 years , Technical support
77.9 mm
22.2 mm
12.05 mm
60 °C
