Kingston DataTraveler R3.0 - USB flash drive - 64 GB - USB 3.0
Quicklinx: 88SSWS00 Mfr#: DTR30/64GB
DataTraveler R3.0
Kingston's DataTraveler® R3.0 USB Flash drive features USB 3.0 high-speed performance to save time and alleviate bottlenecks when transferring files plus offers the rugged protection of a shock-resistant rubber casing. With speeds up to 70MB/s. read and 30MB/s write2 (for USB 3.0), DTR3.0 saves an estimated 22 minutes2 when transferring a 1080p full HD video compared to the same transfer on a standard 2.0 drive, making it 5x faster. It's designed for the latest computers with USB 3.0 ports and is backwards compatible with USB 2.0. Its two-channel architecture provides cost-effective speedy storage in capacities up to 64GB. DataTraveler R3.0 is backed by a five-year warranty, free technical support and legendary Kingston® reliability.
Supports Windows® 8, Windows® 7, Vista®, XP & Mac
USB 3.0 performance; Backwards compatible with USB 2.0
Shock-resistant rubber casing
Speed:
Using USB 3.0: 70MB/s read, 30MB/s write
Using USB 2.0: 30MB/s read, 25MB/s write
  • Rugged design
    The Kingston DataTraveler R3.0 is designed with a rubberized exterior that not only provides a secure grip but also makes it shockproof, ensuring your data stays safe even in the event of drops or impacts.
  • High-speed transfers
    Equipped with USB 3.0 interface, this USB flash drive offers fast read and write speeds of up to 70 MB/s and 30 MB/s, respectively, allowing for quick and efficient data transfers.
  • Wide compatibility
    This flash drive is compatible with both Mac and PC, offering versatile use across different devices without the need for specific drivers or software.
USB flash drive
Interface Type
USB 3.0
Storage Capacity
64 GB
Linux 2.6.x or later, Microsoft Windows Vista SP2, Apple MacOS X 10.5.x or later, Microsoft Windows Vista SP1, Microsoft Windows XP SP3, Microsoft Windows 7 SP1
5-year warranty
USB flash drive
Storage Capacity
64 GB
Read Rate
Up to 70 MB/s
Write Rate
Up to 30 MB/s
Interface Type
USB 3.0
Shockproof, rubberised
Limited warranty - 5 years
70 mm
22.68 mm
12.4 mm
60 °C
