DataTraveler R3.0
Kingston's DataTraveler® R3.0 USB Flash drive features USB 3.0 high-speed performance to save time and alleviate bottlenecks when transferring files plus offers the rugged protection of a shock-resistant rubber casing. With speeds up to 70MB/s. read and 30MB/s write2 (for USB 3.0), DTR3.0 saves an estimated 22 minutes2 when transferring a 1080p full HD video compared to the same transfer on a standard 2.0 drive, making it 5x faster. It's designed for the latest computers with USB 3.0 ports and is backwards compatible with USB 2.0. Its two-channel architecture provides cost-effective speedy storage in capacities up to 64GB. DataTraveler R3.0 is backed by a five-year warranty, free technical support and legendary Kingston® reliability.
Supports Windows® 8, Windows® 7, Vista®, XP & Mac
USB 3.0 performance; Backwards compatible with USB 2.0
Shock-resistant rubber casing
Speed:
Using USB 3.0: 70MB/s read, 30MB/s write
Using USB 2.0: 30MB/s read, 25MB/s write
Rugged design
The Kingston DataTraveler R3.0 is designed with a rubberized exterior that not only provides a secure grip but also makes it shockproof, ensuring your data stays safe even in the event of drops or impacts. -
High-speed transfers
Equipped with USB 3.0 interface, this USB flash drive offers fast read and write speeds of up to 70 MB/s and 30 MB/s, respectively, allowing for quick and efficient data transfers. -
Wide compatibility
This flash drive is compatible with both Mac and PC, offering versatile use across different devices without the need for specific drivers or software.
- Kingston DataTraveler R3.0 - USB flash drive - 32 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.0
- Storage Capacity
- 32 GB
- OS Required
- Linux 2.6.x or later, Microsoft Windows Vista SP2, Apple MacOS X 10.5.x or later, Microsoft Windows Vista SP1, Microsoft Windows XP SP3, Microsoft Windows 7 SP1
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 32 GB
- Read Rate
- Up to 70 MB/s
- Write Rate
- Up to 30 MB/s
- Interface Type
- USB 3.0
- Shockproof, rubberised
- OS Required
- Limited warranty - 5 years
- 70 mm
- 22.68 mm
- 12.4 mm
- 0 °C
- 60 °C
