The Kingston Data Traveler Kyson is a high-performance Type-A USB flash drive with extremely fast transfer speeds of up to 200MB/s Read and 60MB/s Write, allowing quick and convenient file transfers. With up to 64GB of storage, you can store and share photos, videos, music and other content on the go.
Versatile connectivity
The Kingston DataTraveler microDuo G2 offers dual interfaces with USB 3.2 Gen 1 and micro USB, ensuring compatibility with a wide range of devices. This feature allows for seamless data transfer between your computer and mobile devices, making it an ideal solution for on-the-go storage and file sharing. -
Enhanced durability
Equipped with a protective cap, the Kingston DataTraveler microDuo G2 is designed to withstand the rigors of daily use. This added layer of protection helps safeguard the flash drive's connectors from dust, debris, and potential damage, ensuring your data remains safe and accessible when you need it most.
 - Kingston DataTraveler microDuo G2 - USB flash drive - 64 GB
- Product Type
 - USB flash drive
- Interface Type
 - USB 3.2 Gen 1 / micro USB
- Storage Capacity
 - 64 GB
- OS Required
 - Linux 2.6.x or later, Android, Google Chrome OS, Apple MacOS X 10.10.x or later, Windows 8 / 8.1 / 10
 - 3-year warranty
- Product Type
 - USB flash drive
- Storage Capacity
 - 64 GB
- Interface Type
 - USB On-The-Go compatible, micro-USB connector, protective cap
- OS Required
 - Limited warranty - 3 years
 - 26.9 mm
 - 14.4 mm
 - 5.4 mm
 - 1.7 g
 - 0 °C
 - 60 °C
