DataTraveler G4 - USB 3.0 in a colourful design
USB 3.0 performance, backwards compatible with USB 2.0
Colorful loop attaches to key rings
Practical cap to protect USB plug and your data
Kingston's DataTraveler® Generation 4 (DTIG4) USB Flash drive features USB 3.0 for quick and easy transfers of music, video and more. Its practical design and fashionable colours make it ideal for everyday use at work, home, school or wherever you need to take your data.
It's backwards compatible with existing USB 2.0 ports, allowing 2.0 users to migrate to 3.0 in the future without replacing their drive. DTIG4 is backed by a five-year warranty, free technical support and legendary Kingston® reliability.
Capacity:
8GB
Dimensions:
55mm x 21mm x 10.1mm
Warranty/support:
5-year warranty, free technical support
Compatible with:
Windows® 8.1, Windows 8, Windows 7, Windows Vista®, Windows XP, Mac OS X v.10.6+, Linux v.2.6+ (USB 3.0 connectivity requires a USB 3.0 port)
 - Kingston DataTraveler G4 - USB flash drive - 8 GB
- Product Type
 - USB flash drive
- Interface Type
 - USB 3.0
- Storage Capacity
 - 8 GB
- Enclosure Colour
 - Yellow
- OS Required
 - Microsoft Windows XP, Microsoft Windows 7, Linux 2.6.x or later, Microsoft Windows Vista, Apple MacOS X 10.6 or later, Windows 8, Windows 8.1
 - 5-year warranty
- Product Type
 - USB flash drive
- Storage Capacity
 - 8 GB
- Enclosure Colour
 - Yellow
- Interface Type
 - USB 3.0
 - Key ring loop
- OS Required
 - Limited warranty - 5 years
 - 55 mm
 - 10.1 mm
 - 21 mm
 - 0 °C
 - 60 °C
