Kingston DataTraveler I G4 - USB 3.0 - 16GB
Quicklinx: 92FDWS00 Mfr#: DTIG4/16GB
Capacity: 16GB
Interface: USB 3.0
More than 50 in stock
£3.18 ex VAT
£3.81 inc VAT
DataTraveler G4 - USB 3.0 in a colourful design
USB 3.0 performance, backwards compatible with USB 2.0
Colorful loop attaches to key rings
Practical cap to protect USB plug and your data
Kingston's DataTraveler® Generation 4 (DTIG4) USB Flash drive features USB 3.0 for quick and easy transfers of music, video and more. Its practical design and fashionable colours make it ideal for everyday use at work, home, school or wherever you need to take your data.
It's backwards compatible with existing USB 2.0 ports, allowing 2.0 users to migrate to 3.0 in the future without replacing their drive. DTIG4 is backed by a five-year warranty, free technical support and legendary Kingston® reliability.
Capacity:
16GB
Dimensions:
55mm x 21mm x 10.1mm
Warranty/support:
5-year warranty, free technical support
Compatible with:
Windows® 8.1, Windows 8, Windows 7, Windows Vista®, Windows XP, Mac OS X v.10.6+, Linux v.2.6+ (USB 3.0 connectivity requires a USB 3.0 port)
Kingston DataTraveler G4 - USB flash drive - 16 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
16 GB
Enclosure Colour
Blue
Microsoft Windows XP, Microsoft Windows 7, Linux 2.6.x or later, Microsoft Windows Vista, Apple MacOS X 10.6 or later, Windows 8, Windows 8.1
5-year warranty
USB flash drive
Storage Capacity
16 GB
Enclosure Colour
Blue
Compatibility
Non-specific
Interface Type
USB 3.0
Key ring loop
Limited warranty - 5 years
55 mm
10.1 mm
21 mm
60 °C
Capacity: 16GB
Interface: USB 3.0
Brand: Kingston
Price Range Ex VAT: 0 - 50
