Kingston DataTraveler I G3 - USB flash drive - 16 GB - USB 2.0 - white, blue
Quicklinx: 73F2WS00 Mfr#: DTIG3/16GB
Portable storage that carries on the Kingston tradition of quality.
The reliable DataTraveler Generation 3 (G3) is ideal for your important documents, music, video clips and favorite photos that can be stored and retrieved in a flash.
It's a perfect fit for the office, home, school and wherever you travel. A well-built cap protects the USB plug and your data. DataTraveler G3 also makes a great promotional item for your organization, it's simple to add your logo to increase brand recognition.
DataTraveler G3 is backed by legendary Kingston reliability plus a five-year warranty and free tech support.
Kingston DataTraveler G3 - USB flash drive - 16 GB
USB flash drive
Interface Type
USB 2.0
Storage Capacity
16 GB
Enclosure Colour
White, blue
Microsoft Windows XP, Microsoft Windows 2000 SP4, Microsoft Windows 7, Linux 2.6.x or later, Microsoft Windows Vista, Apple MacOS X 10.5.x or later
Microsoft Certification
Works with Windows Vista
5-year warranty
USB flash drive
Storage Capacity
16 GB
Enclosure Colour
White, blue
Read Rate
Up to 10 MB/s
Write Rate
Up to 5 MB/s
Interface Type
USB 2.0
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
Limited warranty - 5 years
65.7 mm
10.7 mm
22.4 mm
60 °C
