DataTraveler HyperX Predator USB flash drive offers the fastest speeds from Kingston and the highest capacities available in the world. With 240 Mbps read and 160 Mbps write speeds (in USB 3.0), users can quickly access, edit and transfer their files and applications directly from the drive with no performance lag. Large capacity allows users to store their entire digital world on the DT HyperX Predator. This prestigious drive is compliant with USB 3.0 specifications and is backwards compatible with USB 2.0 systems. DT HyperX Predator offers superior quality in a high-end design and also features a custom Kingston key ring and HyperX Valet Keychain for added value.
Robust design
Crafted with an aluminum body and equipped with a key ring loop, this USB flash drive is designed for durability and convenience. Its shockproof construction ensures your data stays safe even in the face of accidental drops or impacts. -
High-speed performance
Experience swift data transfer with read rates of up to 240 MB/s and write rates of up to 160 MB/s. Whether you're moving large files, backing up your data, or loading games, it delivers efficient performance. -
Wide compatibility
Designed to work seamlessly with both Mac and PC, this USB flash drive offers versatile compatibility. Its USB 3.0 interface ensures fast data transfer rates and is backward compatible with USB 2.0 ports.
- Kingston DataTraveler HyperX Predator - USB flash drive - 512 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.0
- Storage Capacity
- 512 GB
- OS Required
- Linux 2.6.x or later, Microsoft Windows Vista SP2, Microsoft Windows Vista SP1, Microsoft Windows XP SP3, Apple MacOS X 10.6.x, Microsoft Windows 7 SP1, Windows 8
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 512 GB
- Read Rate
- Up to 240 MB/s
- Write Rate
- Up to 160 MB/s
- Interface Type
- USB 3.0
- Shockproof, metal body, key ring loop
- Included Accessories
- HyperX Valet key chain
- OS Required
- Limited warranty - 5 years
- 88.5 mm
- 26.9 mm
- 21 mm
- 0 °C
- 60 °C
