Kingston DataTraveler Elite 3.0 USB flash drive - 32 GB - USB 3.0
Quicklinx: 81Z5WS00 Mfr#: DTE30/32GB
Kingston's DataTraveler Elite 3.0 USB flash drive is designed based on the USB 3.0 standard and is an economical choice for fast, multi-stream data transfer. It's ideal for desktops and notebooks with USB 3.0 ports and also reduces data transfer times on system with USB 2.0 ports. DataTraveler Elite features a convenient, tri-colored, capless design with a slider.
  • Rapid transfer speeds
    Experience swift data transfer with the Kingston DataTraveler Elite 3.0, boasting read rates of up to 70 MB/s and write rates of 30 MB/s. This USB flash drive ensures efficient file movement, making it ideal for busy professionals and multimedia enthusiasts alike.
  • Broad compatibility
    Designed to serve a wide range of devices, the Kingston DataTraveler Elite 3.0 offers extensive compatibility. Its USB 3.0 interface ensures it can connect seamlessly with any PC, providing a reliable solution for data storage and transfer needs.
  • Durable design
    With an operating temperature range from 0°C to 60°C, the Kingston DataTraveler Elite 3.0 is built to withstand various environmental conditions, ensuring your data is safe and secure no matter where you go.
Kingston DataTraveler Elite 3.0 - USB flash drive - 32 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
32 GB
Enclosure Colour
Black, white, graphite
Linux 2.6.x or later, Microsoft Windows Vista SP2, Apple MacOS X 10.5.x or later, Microsoft Windows Vista SP1, Microsoft Windows XP SP3, Microsoft Windows 7 SP1
5-year warranty
USB flash drive
Storage Capacity
32 GB
Enclosure Colour
Read Rate
Up to 70 MB/s
Write Rate
Up to 30 MB/s
Interface Type
USB 3.0
Sliding lid
Limited warranty - 5 years
69.1 mm
21.6 mm
11.1 mm
60 °C
