Protect your organization's portable data and comply with data-at-rest agency directives by choosing Kingston's ultra-secure DataTraveler 5000 USB Flash drive.
It's FIPS 140-2 Level 2 certified and features 256-bit AES hardware-based encryption in XTS mode. XTS is much stronger than CBC and ECB modes. The DataTraveler 5000 uses elliptic curve cryptography encryption algorithms (ECC) which meet the Suite B standards approved by the U. S. Government.
Complex password protection enforces device lockdown after a specified number of invalid attempts. DataTraveler 5000 is rugged and waterproof, with a titanium-coated, stainless-steel casing for added data protection. And it's easy to set up and use, with no admin rights or application installation required.
Secure
Drive locks down after 10 intrusion attempts and encryption key is destroyed. -
Enforced complex password protection
Password (up to 128 characters) is user set with minimum characteristics to prevent unauthorized access. -
Full privacy
100 percent of stored data is protected by 256-bit Advanced Encryption Standard (AES) hardware-based encryption - master key recreated at logon. -
Customizable
Preload content, full security policy customization. -
Tamper-evident
Tamper-evident coating/seal for physical security. -
Waterproof
Protected against water damage. -
Ruggedized
Waterproof and titanium-coated stainless steel casing.
- Kingston DataTraveler 5000 - USB flash drive - 16 GB
- Product Type
- USB flash drive
- Interface Type
- USB 2.0
- Storage Capacity
- 16 GB
- Hardware Encryption
- Encryption Algorithm
- FIPS 140-2 Level 2, 256-bit AES, 384-bit SHA-2
- OS Required
- Microsoft Windows XP SP1, Microsoft Windows XP SP2, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows XP SP3
- Microsoft Certification
- Compatible with Windows 7
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 16 GB
- Read Rate
- Up to 11 MB/s
- Write Rate
- Up to 5 MB/s
- Interface Type
- USB 2.0
- Password protection, waterproof, malware scanning, ECC support, ruggedized
- OS Required
- Limited warranty - 5 years
- 77.9 mm
- 22 mm
- 12.1 mm
- 0 °C
- 60 °C
