Kingston DataTraveler 5000 - USB flash drive - 16 GB - USB 2.0
Quicklinx: 705SWS00 Mfr#: DT5000/16GB
Protect your organization's portable data and comply with data-at-rest agency directives by choosing Kingston's ultra-secure DataTraveler 5000 USB Flash drive.
It's FIPS 140-2 Level 2 certified and features 256-bit AES hardware-based encryption in XTS mode. XTS is much stronger than CBC and ECB modes. The DataTraveler 5000 uses elliptic curve cryptography encryption algorithms (ECC) which meet the Suite B standards approved by the U. S. Government.
Complex password protection enforces device lockdown after a specified number of invalid attempts. DataTraveler 5000 is rugged and waterproof, with a titanium-coated, stainless-steel casing for added data protection. And it's easy to set up and use, with no admin rights or application installation required.
  • Secure
    Drive locks down after 10 intrusion attempts and encryption key is destroyed.
  • Enforced complex password protection
    Password (up to 128 characters) is user set with minimum characteristics to prevent unauthorized access.
  • Full privacy
    100 percent of stored data is protected by 256-bit Advanced Encryption Standard (AES) hardware-based encryption - master key recreated at logon.
  • Customizable
    Preload content, full security policy customization.
  • Tamper-evident
    Tamper-evident coating/seal for physical security.
  • Waterproof
    Protected against water damage.
  • Ruggedized
    Waterproof and titanium-coated stainless steel casing.
USB flash drive
Interface Type
USB 2.0
Storage Capacity
16 GB
Hardware Encryption
Encryption Algorithm
FIPS 140-2 Level 2, 256-bit AES, 384-bit SHA-2
Microsoft Windows XP SP1, Microsoft Windows XP SP2, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows XP SP3
Microsoft Certification
Compatible with Windows 7
5-year warranty
USB flash drive
Storage Capacity
16 GB
Hardware Encryption
Read Rate
Up to 11 MB/s
Write Rate
Up to 5 MB/s
Interface Type
USB 2.0
Password protection, waterproof, malware scanning, ECC support, ruggedized
Limited warranty - 5 years
77.9 mm
22 mm
12.1 mm
60 °C
