DataTraveler 100 G2 is a stylish drive built with simplicity in mind, allowing you to focus on your data. High quality components maintain the legendary Kingston reliability and the USB connector is safely housed inside the sleek and durable case. Carry all of your documents with you, wherever you go.
Built with simplicity in mind, DataTraveler 100 features a sliding capless design with the USB connector safely housed inside the sleek case, so you won't worry about losing a cap. DataTraveler 100 is available in large capacities to give you plenty of room for all your documents, photos, MP3 files and video clips.
Versatile compatibility
Designed to work seamlessly with both Mac and PC, the Kingston DataTraveler 100 G2 offers a high level of compatibility, ensuring that users can easily transfer and access data across different platforms without the need for additional software. -
Efficient data transfer
With its USB 2.0 interface, this USB flash drive provides a reliable and efficient way to store, transfer, and share data. Whether it's documents, photos, or music, users can expect smooth and swift data transmission.
- Kingston DataTraveler 100 G2 - USB flash drive - 32 GB
- Product Type
- USB flash drive
- Interface Type
- USB 2.0
- Storage Capacity
- 32 GB
- Enclosure Colour
- Black
- OS Required
- Microsoft Windows 2000 SP4, Linux 2.6.x or later, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5.x or later
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 32 GB
- Enclosure Colour
- Black
- Read Rate
- Up to 10 MB/s
- Write Rate
- Up to 5 MB/s
- Interface Type
- USB 2.0
- Retractable connector
- Plug and Play
- OS Required
- Limited warranty - 5 years
- 69.6 mm
- 22.4 mm
- 12.8 mm
- 0 °C
- 60 °C
