Power users will have the ability to store massive amounts of data in a small form factor. DataTraveler Ultimate GT offers superior quality in beautiful design, as it is made of a zinc-alloy metal casing for shock resistance. Its compact size gives the tech enthusiast or professional user an easily portable solution to store and transfer their high capacity files.
Robust design
Crafted with a zinc alloy body, the Kingston DataTraveler offers a durable solution for data storage, ensuring your files are protected in a shockproof casing that withstands daily wear and tear. -
Enhanced compatibility
Designed for versatility, this USB flash drive features a retractable connector, making it easily compatible with a wide range of devices without the need for specific drivers or software. -
Optimal performance
With USB 3.1 interface, the Kingston DataTraveler delivers fast data transfer speeds, allowing for quick and efficient file access and storage, making it a suitable choice for professionals and enthusiasts alike.
- Kingston DataTraveler Ultimate GT - USB flash drive - 1 TB
- Product Type
- USB flash drive
- Interface Type
- USB 3.1
- Storage Capacity
- 1 TB
- OS Required
- Linux 2.6.x or later, Microsoft Windows 7 SP1, Google Chrome OS, Windows 8, Windows 8.1, Windows 10, Apple MacOS X 10.9.x or later
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 1 TB
- Interface Type
- USB 3.1
- Shockproof, retractable connector, zinc alloy body
- OS Required
- Limited warranty - 5 years , Technical support
- 72 mm
- 26.94 mm
- 21 mm
- -25 °C
- 60 °C
