Kingston Data Traveler Ultimate GT 1TB USB 3.1
Quicklinx: CQSCWS00 Mfr#: DTUGT/1TB
Power users will have the ability to store massive amounts of data in a small form factor. DataTraveler Ultimate GT offers superior quality in beautiful design, as it is made of a zinc-alloy metal casing for shock resistance. Its compact size gives the tech enthusiast or professional user an easily portable solution to store and transfer their high capacity files.
  • Robust design
    Crafted with a zinc alloy body, the Kingston DataTraveler offers a durable solution for data storage, ensuring your files are protected in a shockproof casing that withstands daily wear and tear.
  • Enhanced compatibility
    Designed for versatility, this USB flash drive features a retractable connector, making it easily compatible with a wide range of devices without the need for specific drivers or software.
  • Optimal performance
    With USB 3.1 interface, the Kingston DataTraveler delivers fast data transfer speeds, allowing for quick and efficient file access and storage, making it a suitable choice for professionals and enthusiasts alike.
Kingston DataTraveler Ultimate GT - USB flash drive - 1 TB
USB flash drive
Interface Type
USB 3.1
Storage Capacity
1 TB
Linux 2.6.x or later, Microsoft Windows 7 SP1, Google Chrome OS, Windows 8, Windows 8.1, Windows 10, Apple MacOS X 10.9.x or later
5-year warranty
USB flash drive
Storage Capacity
1 TB
Interface Type
USB 3.1
Shockproof, retractable connector, zinc alloy body
Limited warranty - 5 years , Technical support
72 mm
26.94 mm
21 mm
-25 °C
60 °C
