Kingston A400 240GB M.2 2280 SSD
Quicklinx: FM2CWS00 Mfr#: SA400M8/240G
Form Factor: M.2 2280
Capacity: 240GB
Interface: Serial ATA-600
Type: Internal hard drive
£17.83 ex VAT
£21.39 inc VAT
Kingston's A400 solid-state drive dramatically improves the responsiveness of your existing system with incredible boot, loading and transfer times compared to mechanical hard drives. Powered by a controller for read and write speeds of up to 500 MB/s and 450 MB/s, this SSD is 10x faster than a traditional hard drive for higher performance, ultra-responsive multi-tasking and an overall faster system.
  • Faster than a hard drive
    With incredible read/write speeds, the A400 SSD will not only increase performance but can be also used to breathe life into older systems.
  • Rugged
    A400 is shock- and vibration-resistant for rugged reliability when used in notebooks and other mobile computing devices.
  • Ideal for desktops and notebooks
    A400 fits in a wide array of systems. It is ideal for thin and light notebooks with limited space.
Kingston A400 - SSD - 240 GB - SATA 6Gb/s
Solid state drive - internal
240 GB
NAND Flash Memory Type
Triple-level cell (TLC)
M.2 2280
SATA 6Gb/s
Data Transfer Rate
600 MBps
Shock resistant
22 mm x 80 mm x 1.35 mm
6.7 g
3-year warranty
240 GB
M.2 2280
SATA 6Gb/s
Shock resistant
22 mm
80 mm
1.35 mm
6.7 g
Performance
SSD Endurance
80 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
500 MBps (read) / 350 MBps (write)
Reliability
MTBF
1,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - M.2 Card
Compatible Bay
M.2 2280
Power Consumption
0.195 watt (idle) , 0.279 watt (average) , 0.642 watt (read) , 1.535 watt (write)
Limited warranty - 3 years
70 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
Vibration Tolerance (operating)
2.17 g @ 7-800 Hz
Vibration Tolerance (non-operating)
20 g @ 10-2000 Hz
Capacity: 240GB
Brand: Kingston
