Kingston 960GB SSDNow A400 SATA 6Gb/s 2.5"
Quicklinx: DDDBWS00 Mfr#: SA400S37/960G
Form Factor: 2.5
Capacity: 960GB
Interface: Serial ATA-600
Type: Internal hard drive
48 In Stock
£40.61 ex VAT
£48.73 inc VAT
Kingston's A400 solid-state drive dramatically improves the responsiveness of your existing system with incredible boot, loading and transfer times compared to mechanical hard drives. Powered by a controller for read and write speeds of up to 500 MB/s and 450 MB/s, this SSD is 10x faster than a traditional hard drive for higher performance, ultra-responsive multi-tasking and an overall faster system.
  • 10x faster than a HDD
    With incredible read/write speeds the A400 SSD will not only increase performance but can also be used to breathe life into older systems.
  • Rugged
    A400 is shock- and vibration-resistant for rugged reliability when used in notebooks and other mobile computing devices.
  • Ideal for desktops and notebooks
    A400 has a 7 mm form factor to fit in a wider array of systems. It's ideal for slimmer notebooks and in systems with limited available space.
Kingston A400 - SSD - 960 GB - SATA 6Gb/s
Solid state drive - internal
960 GB
NAND Flash Memory Type
Triple-level cell (TLC)
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
69.9 mm x 100 mm x 7 mm
41 g
3-year warranty
960 GB
2.5"
SATA 6Gb/s
69.9 mm
100 mm
7 mm
41 g
Performance
SSD Endurance
300 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
500 MBps (read) / 450 MBps (write)
Reliability
MTBF
1,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
0.195 Watt (idle) , 0.279 Watt (average) , 0.642 Watt (read) , 1.535 Watt (write)
ISO 9001, SGS
Limited warranty - 3 years
70 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
Vibration Tolerance (operating)
2.17 g @ 7-800 Hz
Vibration Tolerance (non-operating)
20 g @ 10-2000 Hz
Form Factor: 2.5
Capacity: 960GB
Brand: Kingston
