Kingston's A400 solid-state drive dramatically improves the responsiveness of your existing system with incredible boot, loading and transfer times compared to mechanical hard drives. Powered by a controller for read and write speeds of up to 500 MB/s and 450 MB/s, this SSD is 10x faster than a traditional hard drive for higher performance, ultra-responsive multi-tasking and an overall faster system.
10x faster than a HDD
With incredible read/write speeds the A400 SSD will not only increase performance but can also be used to breathe life into older systems. -
Rugged
A400 is shock- and vibration-resistant for rugged reliability when used in notebooks and other mobile computing devices. -
Ideal for desktops and notebooks
A400 has a 7 mm form factor to fit in a wider array of systems. It's ideal for slimmer notebooks and in systems with limited available space.
- Kingston A400 - SSD - 960 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 960 GB
- NAND Flash Memory Type
- Triple-level cell (TLC)
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- 69.9 mm x 100 mm x 7 mm
- 41 g
- 3-year warranty
- Capacity
- 960 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- 69.9 mm
- 100 mm
- 7 mm
- 41 g
Performance
- SSD Endurance
- 300 TB
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 500 MBps (read) / 450 MBps (write)
Reliability
- MTBF
- 1,000,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5"
- Power Consumption
- 0.195 watt (idle) , 0.279 watt (average) , 0.642 watt (read) , 1.535 watt (write)
- SGS, ISO 9001
- Limited warranty - 3 years
- 0 °C
- 70 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 85 °C
- Vibration Tolerance (operating)
- 2.17 g @ 7-800 Hz
- Vibration Tolerance (non-operating)
- 20 g @ 10-2000 Hz
