There's the IronKey S1000 USB 3.0 hardware encrypted flash drive - a faster and even more secure solution for safeguarding sensitive data no matter where your employees carry it. Unlike competing drives that force users to sacrifice performance for advanced security, IronKey S1000 helps you win the compliance battle by providing extra layers of encryption along with unparalleled data read / write speeds. With IronKey's powerful on-board controller, IronKey S1000 secure storage drive achieves blazing read speeds.
Faster and more secure mobility
Now there's the IronKey S1000 USB 3.0 hardware encrypted flash drive - a faster and even more secure solution for safeguarding sensitive data no matter where your employees carry it. Unlike competing drives that force users to sacrifice performance for advanced security, IronKey S1000 helps you win the compliance battle by providing extra layers of encryption along with unparalleled data read / write speeds. -
Harness blazing USB 3.0 performance
No more waiting for large data sets or files to transfer. With IronKey's powerful on-board controller, IronKey S1000 secure storage drive achieves blazing read speeds of up to 400 Mb/sec. -
Lock it all down with enhanced encryption
IronKey S1000 drive enables you to meet strict security standards as mandated by governments, industry groups and intelligence agencies around the world. It defends your valuable content using hardware-based XTS-AES 256-bit encryption, which provides stronger protection than CBC and other block cipher modes. -
Secure your data at all times
The IronKey Cryptochip, a proven hardware-based solution, persistently protects your critical data by keeping encryption key management on the device, where it's safe and protected. In addition, IronKey drive automatically protects against brute force password attacks and are immune to BadUSB. Active malware protection helps ensure your mobile workers won't leave your network or enterprise applications vulnerable to hacker attacks. -
Rely on IronKey's rugged design
Built to detect and self-destruct upon physical tampering, IronKey S1000 flash drive features a sleek anodized aluminum chassis for military-grade strength and durability. -
Deploy a user-friendly, versatile solution
IronKey S1000 drive is self-initializing, requiring no special drivers or software for installation. Users simply insert the drive into virtually any host PC, log in using an authorized password, and get to work.
- IronKey Basic S1000 - USB flash drive - 8 GB - TAA Compliant
- Product Type
- USB flash drive
- Interface Type
- USB 3.0
- Storage Capacity
- 8 GB
- Hardware Encryption
- Encryption Algorithm
- FIPS 140-2 Level 3, 256-bit AES-XTS
- Technology
- MLC NAND Flash
- OS Required
- Microsoft Windows Vista SP2, Linux 2.6 or later, Microsoft Windows 7 SP1, Windows 8, Apple MacOS X 10.9 - 10.11, Windows 8.1 / 10
- TAA Compliant
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 8 GB
- Read Rate
- Up to 400 MB/s
- Write Rate
- Up to 300 MB/s
- Interface Type
- USB 3.0
- Technology
- MLC NAND Flash
- Password protection, shockproof, waterproof, tamper-proof, ruggedized, Cryptochip, dust-resistant
- TAA Compliant
- OS Required
- Limited warranty - 5 years
- 82.3 mm
- 21.1 mm
- 9.1 mm
- 32 g
- 0 °C
- 70 °C
