All KingstonĀ® memory modules must perform properly to ensure maximum performance. Therefore, Kingston has developed an industry leading quality process to ensure that Kingston memory delivers superior quality, performance, and 100% compatibility with the computing system the module is designed for. Kingston, the world's largest independent memory manufacturer, has over 2, 000 memory products. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
- Kingston Low Power Kit - DDR2 - kit - 8 GB: 2 x 4 GB - FB-DIMM 240-pin - 667 MHz / PC2-5300 - Fully Buffered
- Product Type
- Memory kit
- Capacity
- 8 GB: 2 x 4 GB
- Memory Type
- DDR2 SDRAM - FB-DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 667 MHz (PC2-5300)
- Fully Buffered
- OEM Manufacturer Equivalent Part Number
- HP 466440-B21
- Limited lifetime warranty (Germany, Austria and France - 10 years)
- Designed For
- HP Workstation xw6600, xw8600; HPE Integrity BL860; ProLiant BL25p G2, BL45p G2, BL465, BL680c G5, BL685, DL160 G5, DL180, DL360 G5, DL365, DL380 G5, DL385 G2, DL580 G5, DL585 G2, ML350 G5, ML370 G5, SB460, xw460; StorageWorks All-in-One Storage System 400r 1.2TB, 400r 1TB, 400r 2TB, SB600c 1.16
- Capacity
- 8 GB: 2 x 4 GB
- Upgrade Type
- System specific
- HP 466440-B21
- DRAM memory kit
- Technology
- DDR2 SDRAM
- Form Factor
- FB-DIMM 240-pin
- Speed
- ECC
- Fully Buffered
- Designed For
- HP Workstation xw6400, xw6600, xw8400, xw8600 , HPE Integrity BL860c , HPE ProLiant BL20p G4, BL25p G2, BL45p G2, BL460c, BL465c, BL480c, BL680c G5, BL685c, DL140 G3, DL160 G5, DL160 G5 1TB SATA Storage Server, DL160 G5 640GB SATA Storage Server, DL160 G5 Storage Server, DL180, DL360 G5, DL360 G5 Base, DL360 G5 Entry, DL360 G5 High Efficiency, DL360 G5 Performance, DL365, DL365 Base, DL365 Entry, DL365 Performance, DL380 G5, DL380 G5 8 TB Data Protection Storage Server, DL380 G5 Base, DL380 G5 Entry, DL380 G5 High Efficiency, DL380 G5 High Performance, DL380 G5 Storage Server 1.16TB SAS Model, DL380 G5 Storage Server 1.2TB SCSI Model, DL380 G5 Storage Server 1.8TB SAS Model, DL380 G5 Storage Server 2TB SATA Model, DL380 G5 Storage Server 3.6TB SAS Model, DL380 G5 Storage Server 4.5TB SATA Model, DL380 G5 Storage Server 9TB SATA Model, DL380 G5 Storage Server Base Model, DL380 G5 Storage Server SAN Storage Model, DL380 G5 x64 SAN Storage Server, DL385 G2, DL385 G2 Base, DL385 G2 Entry, DL385 G2 High Performance, DL580 G4, DL580 G4 High Performance, DL580 G5, DL580 G5 Base, DL580 G5 High Performance, DL585 G2, DL585 G2 Storage Server, ML150 G3, ML350 G5, ML350 G5 1.5 TB Storage Server, ML350 G5 1.8TB SAS Storage Server, ML350 G5 3 TB Storage Server, ML350 G5 960 GB Storage Server, ML350 G5 Base, ML350 G5 Entry, ML370 G5, ML370 G5 Base, ML370 G5 Entry, ML370 G5 High Performance, ML370 G5 Performance, SB460c SAN Gateway Storage Server, xw460c Blade Workstation , HPE StorageWorks All-in-One Storage System 400r 1.2TB SAS Model, 400r 1TB SATA Model, 400r 2TB SATA Model, SB600c 1.16TB Storage Blade
