Kingston manufacture the most reliable memory you can buy for a HP Server. Kingstons legendary reputation is built around reliable memory, that will power your HP server with ease, whether it be for minimal day hours or an enviroment that requires 24/7 uptime all year round. Kingston's legendary reputation is also reflected with the peace of mind of a full lifetime warranty on this HP compatible memory module.
- for HP ZBook 15 G3 Mobile Workstation, 17 G3 Mobile Workstation, Studio G3 Mobile Workstation
- Kingston - DDR4 - module - 8 GB - SO-DIMM 260-pin - 2133 MHz / PC4-17000 - unbuffered
- Product Type
- Memory module
- Capacity
- 8 GB
- Memory Type
- DDR4 SDRAM - SO-DIMM 260-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 2133 MHz (PC4-17000)
- Latency Timings
- CL15
- Unbuffered
- Voltage
- 1.2 V
- Lead Plating
- Gold
- OEM Manufacturer Equivalent Part Number
- HP V1D58AA
- Limited lifetime warranty (Russia - 10 years)
- Designed For
- HP ZBook 15 G3 Mobile Workstation, 15u G3 Mobile Workstation, 17 G3 Mobile Workstation, Studio G3 Mobile Workstation
- Capacity
- 8 GB
- Upgrade Type
- System specific
- HP V1D58AA
- DRAM memory module
- Technology
- DDR4 SDRAM
- Form Factor
- SO-DIMM 260-pin
- Speed
- Latency Timings
- CL15
- ECC
- Unbuffered
- Module Configuration
- 1024 X 72
- Voltage
- 1.2 V
- Lead Plating
- Gold
- Designed For
