Kingston 8GB DDR4 2400MHz SODIMM Memory
Quicklinx: CQSSWS00 Mfr#: KCP424SS8/8
Kingston - DDR4 - 8 GB - SO-DIMM 260-pin - 2400 MHz / PC4-19200 - 1.2 V - unbuffered - non-ECC
Kingston - DDR4 - module - 8 GB - SO-DIMM 260-pin - 2400 MHz / PC4-19200 - unbuffered
Memory module
8 GB
Memory Type
DDR4 SDRAM - SO-DIMM 260-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2400 MHz (PC4-19200)
Single rank, unbuffered
Voltage
1.2 V
Limited lifetime warranty (Russia - 10 years)
8 GB
Upgrade Type
Generic
DRAM memory module
DDR4 SDRAM
SO-DIMM 260-pin
Speed
Non-ECC
Module Configuration
1024 x 64
Chips Organization
X8
Voltage
1.2 V
