Kingston manufacture the most reliable memory you can buy for a Cisco Server. Kingstons legendary reputation is built around reliable memory, that will power your Cisco server with ease, whether it be for minimal day hours or an enviroment that requires 24/7 uptime all year round. Kingston's legendary reputation is also reflected with the peace of mind of a full lifetime warranty on this Cisco compatible memory module.
Each chip that is built onto the Cisco memory board has been scrutnised to the highest level to ensure it meets Kingston's very high quality standards before it enters the manufacturing process. Kingston has developed one of the most advanced testing facilities in the industry for the manufacture of Cisco server memory upgrades. Kingston employs a multi-tiered testing system to ensure quality control throughout the design and manufacturing process of all Dell memory upgrades for Server environments.
- Kingston - DDR4 - module - 8 GB - DIMM 288-pin - 2400 MHz / PC4-19200 - registered
- Product Type
- Memory module
- Capacity
- 8 GB
- Memory Type
- DDR4 SDRAM - DIMM 288-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 2400 MHz (PC4-19200)
- Latency Timings
- CL17
- Registered
- Voltage
- 1.2 V
- Lead Plating
- Gold
- OEM Manufacturer Equivalent Part Number
- Cisco UCS-MR-1X082RV-A
- Limited lifetime warranty (Russia - 10 years)
- Designed For
- Cisco UCS B200 M4, Smart Play 8 B200, SmartPlay B200 M4, SmartPlay Select B200 M4
- Capacity
- 8 GB
- Upgrade Type
- System specific
- DRAM memory module
- Technology
- DDR4 SDRAM
- Form Factor
- DIMM 288-pin
- Speed
- Latency Timings
- CL17
- ECC
- Registered
- Module Configuration
- 1024 X 72
- Voltage
- 1.2 V
- Lead Plating
- Gold
- Designed For
- Cisco UCS SmartPlay B200 M4 Advanced 1, SmartPlay B200 M4 Advanced 2, SmartPlay B200 M4 Advanced 3, SmartPlay B200 M4 Advanced 4, SmartPlay B200 M4 Basic 1, SmartPlay B200 M4 High Core 1, SmartPlay B200 M4 High Core 2, SmartPlay B200 M4 High Frequency 1, SmartPlay B200 M4 High Frequency 2, SmartPlay B200 M4 High Frequency 2 (Not sold Standalone ), SmartPlay B200 M4 High Frequency 3, SmartPlay B200 M4 Standard 1, SmartPlay B200 M4 Standard 1 (Not sold Standalone ), SmartPlay B200 M4 Standard 2, SmartPlay Select B200 M4 Advanced 1, SmartPlay Select B200 M4 Advanced 1 (Not sold Standalone ), SmartPlay Select B200 M4 Advanced 1 (Tracer), SmartPlay Select B200 M4 Advanced 2 (Not sold Standalone ), SmartPlay Select B200 M4 Advanced 2 (Tracer), SmartPlay Select B200 M4 Advanced 3 (Not sold Standalone ), SmartPlay Select B200 M4 Advanced 3 (Tracer), SmartPlay Select B200 M4 Advanced 4, SmartPlay Select B200 M4 Advanced 4 (Not sold Standalone ), SmartPlay Select B200 M4 Advanced 5, SmartPlay Select B200 M4 Advanced 5 (Not sold Standalone ), SmartPlay Select B200 M4 Basic 1, SmartPlay Select B200 M4 Basic 1 (Not sold Standalone ), SmartPlay Select B200 M4 High Core 1, SmartPlay Select B200 M4 High Core 1 (Not sold Standalone ), SmartPlay Select B200 M4 High Core 2 (Not sold Standalone ), SmartPlay Select B200 M4 High Frequency 1 (Not sold Standalone ), SmartPlay Select B200 M4 High Frequency 1 (Tracer), SmartPlay Select B200 M4 High Frequency 2 (Not sold Standalone ), SmartPlay Select B200 M4 High Frequency 2 (Tracer), SmartPlay Select B200 M4 High Frequency 3, SmartPlay Select B200 M4 High Frequency 3 (Not sold Standalone ), SmartPlay Select B200 M4 High Frequency 3 (Tracer), SmartPlay Select B200 M4 Standard 1 (Not sold Standalone ), SmartPlay Select B200 M4 Standard 1 (Tracer), SmartPlay Select B200 M4 Standard 2, SmartPlay Select B200 M4 Standard 2 (Not sold Standalone ), SmartPlay Select B200 M4 Standard 2 (Tracer)
