Kingston 8GB DDR3L 1600MHz SODIMM CL11 Unbuffered Memory
Quicklinx: C371WS00 Mfr#: KCP3L16SD8/8
Type: DDR3L SDRAM
Capacity: 8GB
Connection: SO-DIMM 204-pin
Speed: 800MHz
Data Integrity: Non-ECC
£69.19 ex VAT
£83.02 inc VAT
Kingston 8GB 1600MHz 204-Pin CL11 DDR3L SODIMM Non-ECC Unbuffered 1.35V Memory
Kingston - DDR3L - module - 8 GB - SO-DIMM 204-pin / PC3L-12800 - unbuffered
Memory module
8 GB
Memory Type
DDR3L SDRAM - SO-DIMM 204-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MT/s (PC3L-12800)
Latency Timings
CL11
Low Voltage, unbuffered
Voltage
1.35 V
Lead Plating
Gold
HP H6Y77AA, DELL A7022339, HP H6Y77UT, HP 693374-001, Toshiba PA5104U-1M8G, Lenovo 0B47381, HP 693374-005, HP H6Y77ET, Panasonic CF-KBAS08GM, Apple MF495G/A (1/2)
Limited lifetime warranty (Russia - 10 years)
8 GB
Upgrade Type
Generic
DRAM memory module
DDR3L SDRAM
SO-DIMM 204-pin
Speed
Latency Timings
CL11
Non-ECC
Module Configuration
1024 x 64
Voltage
1.35 V
Lead Plating
Gold
Colour Category
Green
Type: DDR3L SDRAM
Capacity: 8GB
Speed: 800MHz
Registered/Buffered: Unbuffered
CAS Latency: CL11
Standard: PC3L-12800
Brand: Kingston
