Kingston Technology offers extremely reliable, high-performance notebook memory. Every module is customised and tested to meet the exact specification requirements of each system. Kingston memory can increase the processing power of your notebook. It’s guaranteed to be compatible and offers a great cost-performance benefit plus better multitasking, faster processing of multimedia files and smoother video streaming. For added peace of mind, Kingston memory is backed by a lifetime warranty, free technical support and legendary Kingston reliability.
- Expertise - From the industry leader in PC memory
- Superior quality and testing - All components are qualified and all modules are tested at all stages of production.
- Guaranteed compatibility - Kingston memory is guaranteed to be compatible with the system for which it’s designed.
- Lifetime warranty and free technical support
- Kingston system-specific memory for Acer, Apple (iMac, Mac mini, MacBook Pro), Dell, Fujitsu, HP, Lenovo, NEC, Samsung, Sony and Toshiba notebooks (please make sure to always check the system and memory compatibility).
- Kingston - DDR3 - module - 8 GB - SO-DIMM 204-pin - 1600 MHz / PC3-12800 - unbuffered
- Product Type
- Memory module
- Capacity
- 8 GB
- Memory Type
- DDR3 SDRAM - SO-DIMM 204-pin
- Upgrade Type
- System specific
- Data Integrity Check
- Non-ECC
- Speed
- 1600 MHz (PC3-12800)
- Latency Timings
- CL11
- Unbuffered
- Limited lifetime warranty
- Designed For
- HP EliteBook Folio 9470m
- Capacity
- 8 GB
- Upgrade Type
- System specific
- DRAM memory module
- Technology
- DDR3 SDRAM
- Form Factor
- SO-DIMM 204-pin
- Speed
- Latency Timings
- CL11
- Non-ECC
- Unbuffered
- Compatible Slots
- 1 x memory - SO-DIMM 204-pin
- Designed For
