Compact, capless storage in a metal case.
DataTraveler® 50 is a lightweight USB Flash drive available in capacities from 8GB to 128GB. The drive’s compact, capless design features a metal casing that complements any compatible device and colorful accents that range by drive capacity. Fast USB 3.1 Gen 1 (USB 3.0) performance ensures data transfer of music, video and more is quick and easy. Backward compatible with existing USB 2.0 ports for convenience, the drive is also customizable with your logo and/or digital files. DT 50 is backed by a five-year warranty, free technical support and legendary Kingston® reliability.
- Compact, lightweight, capless design
- Metal casing with colorful accent by capacity
- Fast USB 3.1 Gen 1 (USB 3.0) performance
- Customizable with your logo and/or digital files
- Kingston DataTraveler 50 - USB flash drive - 8 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.1 Gen 1
- Storage Capacity
- 8 GB
- Enclosure Colour
- Purple
- OS Required
- Linux 2.6.x or later, Microsoft Windows Vista SP2, Microsoft Windows 7 SP1, Google Chrome OS, Windows 8, Windows 8.1, Windows 10, Apple MacOS X 10.9.x or later
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 8 GB
- Enclosure Colour
- Purple
- Interface Type
- USB 3.1 Gen 1
- Metal body
- OS Required
- Limited warranty - 5 years , Technical support
- 44.9 mm
- 20 mm
- 9.2 mm
- 0 °C
- 60 °C
