Kingston 8GB DataTraveler 50 USB 3.1 Flash Drive Purple
Quicklinx: C9LMWS00 Mfr#: DT50/8GB
Compact, capless storage in a metal case.
DataTraveler® 50 is a lightweight USB Flash drive available in capacities from 8GB to 128GB. The drive’s compact, capless design features a metal casing that complements any compatible device and colorful accents that range by drive capacity. Fast USB 3.1 Gen 1 (USB 3.0) performance ensures data transfer of music, video and more is quick and easy. Backward compatible with existing USB 2.0 ports for convenience, the drive is also customizable with your logo and/or digital files. DT 50 is backed by a five-year warranty, free technical support and legendary Kingston® reliability.
  • Compact, lightweight, capless design
  • Metal casing with colorful accent by capacity
  • Fast USB 3.1 Gen 1 (USB 3.0) performance
  • Customizable with your logo and/or digital files
Kingston DataTraveler 50 - USB flash drive - 8 GB
USB flash drive
Interface Type
USB 3.1 Gen 1
Storage Capacity
8 GB
Enclosure Colour
Purple
Linux 2.6.x or later, Microsoft Windows Vista SP2, Microsoft Windows 7 SP1, Google Chrome OS, Windows 8, Windows 8.1, Windows 10, Apple MacOS X 10.9.x or later
5-year warranty
USB flash drive
Storage Capacity
8 GB
Enclosure Colour
Purple
Interface Type
USB 3.1 Gen 1
Metal body
Limited warranty - 5 years , Technical support
44.9 mm
20 mm
9.2 mm
60 °C
