Kingston ValueRAM Server Premier is designed specifically for mission-critical server systems that require maximum uptime and stability. Server Premier Modules are built using the same components every time and include advanced product change notification (PCN). PCN ensures ample time for qualification and testing at the customer site. With ValueRAM Server Premier, you can expect the same degree of reliability and performance that IT professionals worldwide have come to depend on from Kingston memory.
- Kingston Server Premier - DDR3L - module - 8 GB - DIMM 240-pin - 1600 MHz / PC3L-12800 - registered with parity
- Product Type
- Memory module
- Capacity
- 8 GB
- Memory Type
- DDR3L SDRAM - DIMM 240-pin
- Upgrade Type
- Generic
- Data Integrity Check
- ECC
- Speed
- 1600 MHz (PC3L-12800)
- Latency Timings
- CL11 (11-11-11)
- Temperature monitoring, single rank, eight banks, On-Die Termination (ODT), Low Voltage, registered with parity
- Voltage
- 1.35 / 1.5 V
- Lead Plating
- Gold
- Limited lifetime warranty (Russia - 10 years)
- Capacity
- 8 GB
- Upgrade Type
- Generic
- DRAM memory module
- Technology
- DDR3L SDRAM
- Form Factor
- DIMM 240-pin
- Module Height (inch)
- 1.18
- Speed
- Latency Timings
- CL11 (11-11-11)
- ECC
- Module Configuration
- 1024 X 72
- Chips Organization
- 1024 x 4
- Voltage
- 1.35 / 1.5 V
- Lead Plating
- Gold
