Kingston 8GB (2 x 4GB) XMP 10th Anniversary 1866MHz DDR3 DIMM CL9
Quicklinx: 8H41WS00 Mfr#: KHX18C9X3K2/8X
Kingston's HyperX®10th Anniversary Edition memory celebrates ten years of outstanding performance with a stylish silver heatspreader. It features a low profile to fit under large CPU coolers and enhanced thermal dissipation for long-term memory reliability.
Engineered to outperform the competition, HyperX 10th Anniversary Edition memory delivers impressive frequencies of up to 2400MHz and high capacities of up to 32GB. It's XMP-ready, with XMP profiles built into the modules, so higher performing frequencies, timings and voltage are attainable by simply enabling Intel's Extreme Memory Profile. HyperX 10th Anniversary Edition memory is covered by a lifetime warranty, free technical support and legendary Kingston® reliability.
HyperX Limited Edition 10th Anniversary Series - DDR3 - kit - 8 GB: 2 x 4 GB - DIMM 240-pin - 1866 MHz / PC3-14900 - unbuffered
Memory kit
8 GB: 2 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1866 MHz (PC3-14900)
Latency Timings
CL9 (9-11-9)
Dual rank, eight banks, aluminium heat spreader, On-Die Termination (ODT), Serial Presence Detect (SPD), Intel Extreme Memory Profiles (XMP), unbuffered
Voltage
1.65 V
Lead Plating
Gold
8 GB: 2 x 4 GB
Upgrade Type
Generic
DRAM memory kit
DDR3 SDRAM
DIMM 240-pin
Module Height (inch)
1.18
Speed
Latency Timings
CL9 (9-11-9)
Non-ECC
Module Configuration
512 x 64
Chips Organization
256 x 8
Voltage
1.65 V
Lead Plating
Gold
Compatible Slots
2 x memory - DIMM 240-pin
UL 94 V-0
