Kingston 8GB (2 x 4GB) HyperX Predator DDR3 1866MHz DIMM CL9 XMP
Quicklinx: 88H6WS00 Mfr#: KHX18C9T2K2/8X
Kingston® HyperX® Predator memory features fast speeds, low latencies and high capacities.
Push your system to the max. Kingston® HyperX® Predator takes performance to thrilling new extremes with the fastest speeds, lowest latencies and highest capacities available in HyperX memory. It has a new heat spreader for greater heat dissipation, plus it's Intel XMP Certified and compatible with all popular brands of motherboards.
HyperX Predator is ultra-reliable and 100-percent factory tested to ensure higher performance, ultra-responsive multitasking and a faster system. Users can overclock their platforms simply by selecting a profile, with no need for manual adjustments in BIOS. HyperX Predator is backed by a lifetime warranty, free technical support and legendary Kingston reliability.
  • Compatible -- tested with all popular brands of motherboards
  • Reliable -- 100-percent factory tested
  • Easy to install
  • Guaranteed -- lifetime warranty, free technical support
  • Dense heat spreader for ultimate heat dissipation
  • Intel XMP Certified
HyperX Predator - DDR3 - kit - 8 GB: 2 x 4 GB - DIMM 240-pin - 1866 MHz / PC3-14900 - unbuffered
Memory kit
8 GB: 2 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1866 MHz (PC3-14900)
Latency Timings
CL9 (9-11-9)
Heat sink, dual rank, eight banks, On-Die Termination (ODT), Intel Extreme Memory Profiles (XMP), dual channel, unbuffered
Voltage
1.65 V
Lead Plating
Gold
8 GB: 2 x 4 GB
Upgrade Type
Generic
DRAM memory kit
DDR3 SDRAM
DIMM 240-pin
Module Height (inch)
1.18
Speed
Latency Timings
CL9 (9-11-9)
Non-ECC
Module Configuration
512 x 64
Chips Organization
256 x 8
Voltage
1.65 V
Lead Plating
Gold
Compatible Slots
2 x memory - DIMM 240-pin
Resources
The following resources are available for the Kingston 8GB (2 x 4GB) HyperX Predator DDR3 1866MHz DIMM CL9 XMP
