Kingston's HyperX red memory features a redesigned heat spreader and a bold color to complement high-performance systems.
- HyperX blu Red Series - DDR3 - kit - 8 GB: 2 x 4 GB - DIMM 240-pin - 1333 MHz / PC3-10600 - unbuffered
- Product Type
- Memory kit
- Capacity
- 8 GB: 2 x 4 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 1333 MHz (PC3-10600)
- Latency Timings
- CL9 (9-9-9)
- Aluminium heat spreader, unbuffered
- Voltage
- 1.5 V
- Lead Plating
- Gold
- Limited lifetime warranty
- Capacity
- 8 GB: 2 x 4 GB
- Upgrade Type
- Generic
- DRAM memory kit
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Latency Timings
- CL9 (9-9-9)
- Non-ECC
- Module Configuration
- 512 x 64
- Voltage
- 1.5 V
- Lead Plating
- Gold
- Compatible Slots
- 2 x memory - DIMM 240-pin
