Kingston 800GB DCP1000 NVMe PCIe SSD
Quicklinx: DD4TWS00 Mfr#: SEDC1000H/800G
Kingston's DCP1000 SSD has flexible drive topology and supports flexible software RAID capability to save on redundant hardware costs.
  • Robust durability
    Engineered to withstand tough conditions, the Kingston SSDNow DCP1000 features shock and vibration tolerance with a high MTBF of 2,000,000 hours, ensuring reliability and longevity.
  • Exceptional performance
    With an impressive 4KB random read of 900,000 IOPS and write of 145,000 IOPS, coupled with data transfer rates up to 7 GBps, this SSD delivers speed for high-performance computing, online transaction processing, and more.
  • Advanced data protection
    The SSDNow DCP1000 comes equipped with power loss protection and power failure protection, safeguarding your data even in the most unexpected scenarios.
Kingston SSDNow DCP1000 - SSD - 800 GB - PCIe 3.0 x8 (NVMe)
Solid state drive - internal
800 GB
PCIe 3.0 x8 (NVMe)
Data Transfer Rate
7 GBps
Online Transaction Processing (OLTP), High-Performance Computing (HPC), Non-volatile Flash Memory, power failure protection, Power Loss Protection (PLP), S.M.A.R.T.
18 mm x 168 mm x 69 mm
209 g
5-year warranty
800 GB
PCIe 3.0 x8 (NVMe)
18 mm
168 mm
69 mm
209 g
Performance
SSD Endurance
748 TB
Drive Transfer Rate
7 GBps (external)
Internal Data Rate
6800 MBps (read) / 5000 MBps (write)
4KB Random Read
900000 IOPS
4KB Random Write
145000 IOPS
Average Latency
30 µs
Reliability
MTBF
2,000,000 hours
Expansion & Connectivity
1 x PCI Express 3.0 x8 (NVMe)
Power Consumption
35 Watt (active)
Microsoft Windows 7, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012 R2, Windows 8.1, VMware vSphere 5.5, Windows 10, VMware vSphere 6.0, Linux Kernel 3.3, FreeBSD 11
Limited warranty - 5 years , Technical support
70 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
Vibration Tolerance (operating)
2.17 g @ 7-800 Hz
Vibration Tolerance (non-operating)
20 g @ 10-2000 Hz
