Kingston 6GB DDR4-2133MHz Reg ECC Memory
Quicklinx: DQQ9WS00 Mfr#: KTL-TS421/16G
Kingston DDR4 16 GB DIMM 288-pin 2133 MHz / PC4-17000 CL15 1.2 V registered ECC for Lenovo ThinkServer RD350; RD450; RD550; RD650; TD350
Kingston - DDR4 - module - 16 GB - DIMM 288-pin - 2133 MHz / PC4-17000 - registered
Memory module
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15
Registered
Voltage
1.2 V
Lead Plating
Gold
Lenovo 4X70F28590
Limited lifetime warranty (Russia - 10 years)
Lenovo ThinkServer RD350 70D6, 70D8, 70D9, 70QK, 70QM; RD450 70DA, 70DB, 70DC, 70DD, 70DE, 70DV, 70DW; RD550 70CV, 70CX, 70CY; RD650 70D0, 70D1, 70D2, 70D3, 70D5, 70DS, 70DU; TD350 70DG, 70DH, 70DJ, 70DK, 70DM, 70DQ
16 GB
Upgrade Type
System specific
Lenovo 4X70F28590
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL15
ECC
Registered
Module Configuration
2048 x 72
Voltage
1.2 V
Lead Plating
Gold
Lenovo ThinkServer RD350 70D6, 70D8, 70D9, 70QK, 70QM , Lenovo ThinkServer RD450 70DA, 70DB, 70DC, 70DD, 70DE, 70DV, 70DW , Lenovo ThinkServer RD550 70CV, 70CX, 70CY , Lenovo ThinkServer RD650 70D0, 70D1, 70D2, 70D3, 70D5, 70DS, 70DU , Lenovo ThinkServer TD350 70DG, 70DH, 70DJ, 70DK, 70DM, 70DQ
