Kingston 64GB IronKey W700 WTG FIPS USB 3.0
Quicklinx: BZTCWS00 Mfr#: IKW700/64GB
Today’s organizations are employing more mobile workers than ever before. Field personnel, consultants and teleworkers all need a mobile computing environment that gives them access to corporate applications and data, without the burden or expense of lugging a laptop. For many enterprises, that environment is Microsoft Windows To Go, a complete Windows 8 Enterprise workspace that can be booted directly from a USB flash drive or other storage device to run on any PC1, regardless of operating system. With Windows To Go, you can: • Provide your users with an imaged and fully functional version of Windows 8 Enterprise. • Distribute mobile work environments that mirror your corporate desktop. • Ensure employees, partners and contractors are using mobile workspaces created and managed by IT. Not every mobile Windows solution is created equal. And when you’re working with corporate data and applications, you need a solution you can trust. Now there’s IronKey Workspace W700 — the drive certified by Microsoft for Windows To Go that delivers a true Windows 8 desktop embedded in a trusted IronKey USB flash drive.
  • Mobilize with windows to go
    Ensure your workforce is using mobile workspaces created and managed by IT, and that are certified by Microsoft for Windows To Go.
  • Protect workspaces with military-grade security
    Trust mobile workspaces to flash drives combining military-grade security and strong, built-in hardware encryption capabilities to help you control user access to desktops, sensitive data and critical applications.
  • Comply with strict data security mandates
    IronKey Workspace W700 drives are FIPS 140-2 Level 3 certified and feature XTS-AES 256-bit hardware encryption, so you can be confident you're complying with regulatory requirements for security data.
  • Depend on ironkey drives built to last
    IronKey Workspace W700 drives undergo thousands of hours of rigorous read/write tests, and we encase each one in a sturdy, tamper-evident metal chassis that's resistant to dust, shocks and waterproof to military standards.
  • Workspaces that keep your people working
    IronKey Workspace W700 drives deliver more than five times the minimum requirements for Windows To Go devices. Users will get sequential read performance of up to 400 MB/second and sequential write speeds of up to 316 MB/second.
IronKey Workspace W700 - USB flash drive - Windows To Go certified - 64 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
64 GB
Hardware Encryption
Encryption Algorithm
FIPS 140-2 Level 3, 256-bit AES, 256-bit AES-XTS
Microsoft Windows 7 or later
Windows To Go Certification
5-year warranty
USB flash drive
Storage Capacity
64 GB
Hardware Encryption
Read Rate
Up to 400 MB/s
Write Rate
Up to 316 MB/s
Interface Type
USB 3.0
Encryption support, bootable, password protection, shockproof, waterproof, dustproof, ruggedized, metal body, Cryptochip, CAC/PIV login
Limited warranty - 5 years
82.3 mm
21.1 mm
9.1 mm
32 g
70 °C
