HyperX Savage USB Flash drive offers blazing fast speeds of up to 350 MB/s to save time during file transfers and let you quickly access, edit and transfer files from the drive without any performance lag. It's compliant with USB 3.1 Gen 1 specifications to take advantage of USB 3.1 ports in desktops and notebooks and also backward compatible with USB 3.0 and USB 2.0. HyperX Savage is a stylish drive, with a sleek black casing and signature HyperX logo in red and an aggressive look. It's designed to work on multiple platforms and game consoles, including PS4, PS3, Xbox One and Xbox 360.
Blazing fast transfer speeds
HyperX Savage delivers blazing transfer speeds of 350 MB/s read and 180 MB/s write to save time and let you quickly access files with no performance lag. -
USB 3.1 Gen 1 functionality
HyperX Savage is compliant with USB 3.1 Gen 1 specifications to let you take advantage of USB 3.0 ports in newer notebooks and desktops. -
Bold design
This stylish drive has an aggressive look that complements the latest PCs and consoles. Its sleek black casing is accented with the signature HyperX logo in metallic red. -
Multi-platform compatibility
Use this versatile drive on multiple platforms, including desktops, notebooks and gaming consoles, including PS4, PS3, Xbox One and Xbox 360. Its slim design fits in tight console USB ports, and it lets console users quickly transfer their profiles.
- HyperX Savage - USB flash drive - 64 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.1
- Storage Capacity
- 64 GB
- Enclosure Colour
- Black, red metallic
- OS Required
- Microsoft Windows Vista SP2, Linux 2.6 or later, Microsoft Windows 7 SP1, Windows 8, Apple MacOS X 10.8 or later, Windows 8.1, Windows 10
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 64 GB
- Enclosure Colour
- Read Rate
- Up to 350 MB/s
- Write Rate
- Up to 180 MB/s
- Interface Type
- USB 3.1
- Key ring loop
- OS Required
- Limited warranty - 5 years
- 76.3 mm
- 23.48 mm
- 12.17 mm
- 0 °C
- 60 °C
