Kingston’s Canvas Select™ SD card is designed to be reliable, making it ideal for filming in HD and shooting hi-resolution photos on your point-and-shoot camera. This card is tested to be durable1, so you can take it anywhere with confidence that your photos, videos and other data will be protected.
Full HD
The advanced UHS-I interface makes the card ideal for cinema-quality full HD (1080p) and 3D video. -
Made for video
Capture your holiday, football game or night on the town using this Class 10 card. -
Get your memories faster
Transfer and edit your memories quicker thanks to the incredible 8x read speeds over traditional Class 10 SD cards.
- Kingston Canvas Select - flash memory card - 64 GB - SDXC UHS-I
- Product Type
- Flash memory card
- Form Factor
- SDXC UHS-I Memory Card
- Storage Capacity
- 64 GB
- Speed Rating
- UHS-I U1 / Class10
- Limited lifetime warranty
- Product Type
- Flash memory card
- Storage Capacity
- 64 GB
- Speed Class
- Read Rate
- Up to 80 MB/s
- Write Rate
- Up to 10 MB/s
- Form Factor
- Shockproof, waterproof, vibration-proof, X-ray-proof, temperature-proof
- Limited warranty - lifetime
- 24 mm
- 32 mm
- 2.1 mm
- -25 °C
- 85 °C
