Kingston 64Gb Canvas Go Class 10 MicroSD UHS-I
Quicklinx: DK4VWS00 Mfr#: SDCG2/64GB
Kingston's Canvas Go! card is designed to be mobile, making it ideal for filming life's adventures. You can be confident that your memories will be safe when documenting the next journey on your drone or dash cam.
Kingston Canvas Go! - flash memory card - 64 GB - microSDXC UHS-I
Flash memory card
microSDXC UHS-I Memory Card
Storage Capacity
64 GB
Speed Rating
Video Class V30 / UHS-I U3 / Class10
Included Memory Adapter
microSDXC to SD adapter
Flash memory card
Storage Capacity
64 GB
Speed Class
Read Rate
Up to 90 MB/s
Write Rate
Up to 45 MB/s
Shockproof, waterproof, vibration-proof, X-ray-proof, temperature-proof
Limited warranty - lifetime
11 mm
15 mm
Thickness
1 mm
-25 °C
85 °C
