Kingston's DataTraveler Vault Privacy 3.0 (DTVP 3.0) USB flash drive provides affordable business-grade security with 256-bit AES hardware-based encryption using XTS block cipher mode, which offers stronger protection than CBC and ECB modes. It protects 100 per cent of stored data and enforces complex password protection with minimum characteristics to prevent unauthorized access. For additional peace of mind, the drive locks down and reformats after 10 intrusion attempts. It also features a read-only access mode to avoid potential malware risks.
Enhanced security
With built-in password protection, the Kingston DataTraveler Vault Privacy 3.0 ensures your data remains secure and accessible only to authorized users. This feature provides peace of mind, knowing your sensitive information is well-protected against unauthorized access. -
Durable design
Designed to withstand the elements, this USB flash drive is waterproof, offering an extra layer of protection for your data in various environments. Whether you're caught in the rain or accidentally drop it in water, your data stays safe. -
Reliable storage
Utilizing NAND Flash technology, the Kingston DataTraveler Vault Privacy 3.0 offers reliable storage for your files. This technology ensures fast and efficient data transfer, making it an ideal solution for storing and accessing your documents, photos, and videos. -
Secure encryption
The hardware encryption feature adds an additional layer of security, ensuring that your files are encrypted and protected from potential threats. This makes the Kingston DataTraveler Vault Privacy 3.0 an excellent choice for professionals and individuals who prioritize data security. -
Compliance assured
Being TAA-compliant, this USB flash drive meets the requirements for government and military use, making it suitable for a wide range of professional applications where compliance is critical.
- Kingston DataTraveler Vault Privacy 3.0 - USB flash drive - 64 GB - TAA Compliant
- Product Type
- USB flash drive
- Interface Type
- USB 3.0
- Storage Capacity
- 64 GB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES
- Technology
- NAND Flash
- OS Required
- Microsoft Windows Vista SP2, Linux 2.6 or later, Microsoft Windows XP SP3, Apple MacOS X 10.6.x or later, Microsoft Windows 7 SP1, Windows 8
- TAA Compliant
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 64 GB
- 256-bit AES
- Read Rate
- Up to 250 MB/s
- Write Rate
- Up to 85 MB/s
- Interface Type
- USB 3.0
- Technology
- NAND Flash
- Password protection, waterproof
- TAA Compliant
- OS Required
- Limited warranty - 5 years
- 77.9 mm
- 22 mm
- 12.05 mm
- 0 °C
- 60 °C
