Kingston 60GB SSDNow V300 SATA3 2.5" 7MM solid state drive
Quicklinx: 8F70WS00 Mfr#: SV300S37A/60G
Kingston's SSDNow V300 solid-state drive is a cost-effective way to revive your computer. It's 10x faster than a hard drive plus more reliable, more durable and shock-proof. It features an LSI SandForce controller customized for Kingston and best-in-class components, and is available in kits with all the accessories needed for an effortless transition to the latest technology. For added peace of mind, it's backed by a three-year warranty, free technical support and legendary Kingston reliability.
Compressible Data Transfer (ATTO)
  • All capacities: 450MB/s Read and 450MB/s Write
Incompressible Data Transfer (AS-SSD and CrystalDiskMark)
  • 60GB -- 150MB/s Read and 50MB/s Write
  • 120GB -- 180MB/s Read and 133MB/s Write
  • 240GB -- 191MB/s Read and 142MB/s Write
  • 480GB -- 450MB/s Read and 208MB/s Write
IOMETER Maximum Random 4k Read/Write
  • 60GB -- up to 85,000/ up to 60,000 IOPS
  • 120GB -- up to 85,000/ up to 55,000 IOPS
  • 240GB -- up to 85,000/ up to 43,000 IOPS
  • 480GB -- up to 73,000/ up to 28,000 IOPS
PCMARK® Vantage HDD Suite Score
  • 60GB: 39,000
  • 120GB: 49,000
  • 240GB: 57,000
  • 480GB: 57,000
Kingston SSDNow V300 - SSD - 60 GB - SATA 6Gb/s
Solid state drive - internal
60 GB
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Shock resistant
69.8 mm x 100.1 mm x 7 mm
86 g
Microsoft Certification
Compatible with Windows 7
3-year warranty
60 GB
2.5"
SATA 6Gb/s
Shock resistant
69.8 mm
100.1 mm
7 mm
86 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
450 MBps (read) / 450 MBps (write)
Maximum 4KB Random Write
60000 IOPS
Reliability
MTBF
1,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
2.052 watt (active) , 0.64 watt (idle)
Limited warranty - 3 years , Technical support
70 °C
Vibration Tolerance
2.17 g @ 7-800 Hz (operating) / 20 g @ 10-2000 Hz (non-operating)
