Kingston 512GB KC600 2.5" 7mm SATA 6Gb/s SSD
Quicklinx: FHCHWS00 Mfr#: SKC600/512G
Form Factor: 2.5
Capacity: 512GB
Interface: Serial ATA-600
Type: Internal hard drive
Hurry, only 2 left in stock!
£115.64 ex VAT
£138.76 inc VAT
Kingston's KC600 is a full capacity SSD designed to provide remarkable performance and optimized to provide functional system responsiveness with incredible boot, loading, and transfer times. The KC600 utilizes 3D TLC NAND technology while supporting a full-security suite.
  • Easy installation/upgrade
    KC600 is available in an upgrade bundle kit that has everything you need to easily install your drive.
  • Full-security suite
    Protect and secure your data with Kingston's self-encrypting drive.
Kingston KC600 - SSD - 512 GB - SATA 6Gb/s
Solid state drive - internal
512 GB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
3D triple-level cell (TLC)
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
3D NAND Technology, Silicon Motion SM2259 controller, eDrive
69.85 mm x 100.1 mm x 7 mm
40 g
5-year warranty
512 GB
Hardware Encryption
256-bit AES
2.5"
SATA 6Gb/s
69.85 mm
100.1 mm
7 mm
40 g
Performance
SSD Endurance
300 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
550 MBps (read) / 520 MBps (write)
Maximum 4KB Random Write
80000 IOPS
Maximum 4KB Random Read
90000 IOPS
Reliability
MTBF
1,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
0.2 watt (average) , 0.06 watt (idle) , 1.3 watt (read) , 3.2 watt (write)
Limited warranty - 5 years , Technical support
70 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
Vibration Tolerance (operating)
2.17 g @ 7-800 Hz
Vibration Tolerance (non-operating)
20 g @ 10-2000 Hz
Form Factor: 2.5
Capacity: 512GB
Brand: Kingston
