Kingston 512GB Canvas Select Plus SD Card
Quicklinx: FQB0WS00 Mfr#: SDS2/512GB
£29.54 ex VAT
£35.44 inc VAT
Kingston’s Canvas Select Plus SD card is designed with exceptional performance, speed, and durability for heavy workloads such as transferring and developing high-resolution photos or capturing and editing Full HD videos. It can reach Class 10 UHS-I speeds up to 100MB/s for easy storage and quick transfers along with an advanced UHS-I interface that can record cinematic Full HD and 4K Ultra HD videos. The Canvas Select Plus SD card is built to perform in the harshest environments and conditions so you can take it anywhere knowing your files, photos, and videos are protected.
  • Faster speeds
    Class 10 UHS-I speeds up to 100MB/s.
  • Capture in Full HD & 4K UHD video (1080p)
    The advanced UHS-I interface makes the card ideal for cinema-quality Full HD (1080p).
  • Excellent capacity
    Great capacity to store all your memorable photos and videos.
  • Durable
    For your peace of mind, the card is waterproof, temperature proof, shock and vibration proof and X-ray proof.
Kingston Canvas Select Plus - flash memory card - 512 GB - SDXC UHS-I
Flash memory card
SDXC UHS-I Memory Card
Storage Capacity
512 GB
Speed Rating
Video Class V30 / UHS-I U3 / Class10
Flash memory card
Storage Capacity
512 GB
Speed Class
Read Rate
Up to 100 MB/s
Write Rate
Up to 85 MB/s
Shockproof, waterproof, vibration-proof, X-ray-proof, temperature-proof
Limited warranty - lifetime
24 mm
32 mm
2.1 mm
-25 °C
85 °C
Type: SDXC UHS-I Memory Card
Capacity: 512GB
SD Speed Class: Video Class V30 / UHS-I U3 / Class10
Brand: Kingston
