Kingston 500GB KC2000 NVMe PCIe SSD
Quicklinx: F6MJWS00 Mfr#: SKC2000M8/500G
  • Enhanced durability
    With an MTBF of 2,000,000 hours and built-in 256-bit AES hardware encryption, the Kingston KC2000 offers reliability and security for your data, ensuring peace of mind with every use.
  • High-speed performance
    Equipped with a SMI 2262EN controller and utilizing PCI Express 3.0 x4 (NVMe) interface, the KC2000 delivers impressive internal data rates of up to 3000 MB/s read and 2000 MB/s write, making it ideal for fast-paced environments and demanding applications.
  • Advanced storage technology
    Featuring 96-layer 3D NAND technology and a capacity of 500 GB, this SSD provides ample space and enhanced efficiency for your storage needs.
  • Energy efficient
    With power consumption as low as 0.003 watts in idle mode, the KC2000 is designed for efficiency, reducing energy costs while maintaining high performance.
  • Robust environmental tolerance
    Capable of operating in a wide range of temperatures from 0°C to 70°C and designed to withstand vibrations, this SSD ensures consistent performance in various conditions.
Kingston KC2000 - SSD - 500 GB - PCIe 3.0 x4 (NVMe)
Solid state drive - internal
500 GB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
3D triple-level cell (TLC)
M.2 2280
PCIe 3.0 x4 (NVMe)
Microsoft eDrive compatible, NVM Express (NVMe), 96-layer 3D NAND technology, SMI 2262EN controller
22 mm x 80 mm x 3.5 mm
10 g
5-year warranty
500 GB
Hardware Encryption
256-bit AES
M.2 2280
PCIe 3.0 x4 (NVMe)
22 mm
80 mm
3.5 mm
10 g
Performance
SSD Endurance
300 TB
Internal Data Rate
3000 MBps (read) / 2000 MBps (write)
4KB Random Read
350000 IOPS
4KB Random Write
250000 IOPS
Reliability
MTBF
2,000,000 hours
Expansion & Connectivity
1 x PCI Express 3.0 x4 (NVMe) - M.2 Card
Compatible Bay
M.2 2280
Power Consumption
0.003 Watt (idle) , 0.2 Watt (average) , 2.1 Watt (read) , 7 Watt (write)
Limited warranty - 5 years , Technical support
70 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
Vibration Tolerance (operating)
2.17 g @ 7-800 Hz
Vibration Tolerance (non-operating)
20 g @ 20-1000 Hz
