Kingston 4GB Kit
Kingston 4GB Kit
Quicklinx: 4L0XWS00 Mfr#: KTH-XW9400K2/4G
Kingston is the world's largest independent memory manufacturer. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
Kingston - DDR2 - kit - 4 GB: 2 x 2 GB - DIMM 240-pin - 667 MHz / PC2-5300 - registered
Memory kit
4 GB: 2 x 2 GB
Memory Type
DDR2 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
667 MHz (PC2-5300)
Registered
HP 408853-B21, HP EV283AA (x2)
Limited lifetime warranty (Germany, Austria and France - 10 years)
HP Workstation xw9400; HPE ProLiant BL465c, DL385 G2, DL585 G2
4 GB: 2 x 2 GB
Upgrade Type
System specific
DRAM memory kit
DDR2 SDRAM
DIMM 240-pin
Speed
667 MHz (PC2-5300)
ECC
Registered
HP Workstation xw9400 , HPE ProLiant BL465c, DL385 G2, DL585 G2
