Self-defending IronKey Basic drive is hardened to stand up to malware or mischief, so confidential data stays where it belongs. And after 10 failed consecutive password attempts, the device will either self-destruct or reset back to its default state. High-grade memory and strong security make IronKey Basic drive an ideal platform for deploying portable applications and virtual desktops.
Enforce compliance with always-on encryption
Be confident you're protecting sensitive data and meeting regulatory requirements by deploying FIPS 140-2 Level 3 validated IronKey flash drives featuring AES 256-bit hardware encryption. -
Minimize risks associated with lost or stolen drives
Self-defending IronKey Basic drive is hardened to stand up to malware or mischief, so confidential data stays where it belongs. And after 10 failed consecutive password attempts, the device will either self-destruct or reset back to its default state. -
Keep employees productive and applications safe
High-grade memory and strong security make IronKey Basic drive an ideal platform for deploying portable applications and virtual desktops. -
Streamline usability with localized control panel
Reduce help desk calls with self-service password reset and an intuitive user control panel available in eight languages. -
Count on Ironkey's ruggedized design and metal chassis
Internal components are sealed with epoxy to protect against tampering. -
Deploy easily, use simply
Secure your data without burdening users with software or driver installation. Drives include drag-and-drop encryption, Plug-and-Play simplicity, and intuitive encrypted backup.
- IronKey Basic D250 - USB flash drive - 4 GB
- Product Type
- USB flash drive
- Interface Type
- USB 2.0
- Storage Capacity
- 4 GB
- Hardware Encryption
- Encryption Algorithm
- FIPS 140-2 Level 3, 2048-bit RSA, 256-bit SHA, 256-bit AES-CBC
- Technology
- MLC NAND Flash
- OS Required
- Microsoft Windows Vista SP2, Linux 2.6 or later, Microsoft Windows 7 SP1, Windows 8, Windows 8.1 / 10, Apple MacOS X 10.9.x - 10.11.x
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 4 GB
- Read Rate
- Up to 29 MB/s
- Write Rate
- Up to 13 MB/s
- Interface Type
- USB 2.0
- Technology
- MLC NAND Flash
- Password protection, waterproof, tamper-proof, ruggedized, metal body, Cryptochip
- OS Required
- Limited warranty - 5 years
- 75 mm
- 19 mm
- 9 mm
- 25 g
- 0 °C
- 70 °C
